| Pallet size | 800 mm × 800 mm |
| Tool shank (standard) | HSK-A100 |
| Max. spindle speed | 10000 min-1 (rpm) |
| Max. workpiece size | Φ1600 mm × 1100 mm |
Horizontal Machining Centers
FF-1250H
- Meeting the needs of large aluminum workpiece machining
- Tilting rotary table for large workpieces
- Machine structure specialized for process integration contributes to shortening production lead times and high productivity
The rise of electric vehicles against a backdrop of strengthening environmental regulations has led to an increased need for machining large aluminum workpieces to form integral vehicle parts. The FF-1250H has a machine structure specialized for process integration, contributing to shortening production lead times and increasing productivity in the machining of large aluminum workpieces.
        Large 2-axis table for machining large workpieces
2-axis rotary table
The tilting rotary table, which has two rotary axis (A- and B-axis), can change the workpiece orientation freely, enabling multi-surface continuous machining without setup changes.
        Table size capable of loading large workpieces
The large 2-axis table has a high rigidity due to the base structure with support on both ends.
Maximum loading workpiece size:
Φ1600 mm × 1100 mm, 650 kg
        HSK-A100 spindle for heavy duty machining of aluminum workpieces
Equipped with a standard 10,000 min-1 spindle for large-diameter face mills and heavy-duty tools with special shapes.
Maximum tool diameter / length / weight:
Φ250 mm / 450 mm / 30 kg
        Automation
You can build automation lines of various sizes, from space-saving processing lines that combine with gantry loaders to large-scale processing lines that combine with loader robots that load materials and remove finished products.
The digital setup function can replicate the machine of your factory in the PC at your office. On the machine side, operation programs can be created while checking the workpiece shape and process, intuitively with touch panel controls.
