| Pallet size | 400 mm × 400 mm |
| Tool shank | BT40 |
| Max. workpiece size | Φ630 mm × 900 mm |
Horizontal Machining Center
HCN NEO
- A wide range of spindle variations that allow machining under optimal cutting condition
- Reduced non-operating time and improved productivity with NC rotary table (standard equipment)
- Long-term, high precision machining made possible by high rigidity structure and state-of-the-art compensation technology
- Wide variety of automation systems are available
Largest X, Y, and Z-axis stroke and workpiece size in its class
HCN-4000 NEO
| Pallet dimensions | 400 mm × 400 mm |
| X-axis / Y-axis / Z-axis stroke | 560 mm / 640 mm / 640 mm |
HCN-5000 NEO
| Pallet dimensions | 500 mm × 500 mm |
| X-axis / Y-axis / Z-axis stroke | 730 mm / 730 mm / 800 mm |
HCN-6800 NEO
| Pallet dimensions | 630 mm × 630 mm |
| X-axis / Y-axis / Z-axis stroke | 1050 mm / 900 mm / 980 mm |
HCN-8800 NEO
| Pallet dimensions | 800 mm × 800 mm |
| X-axis / Y-axis / Z-axis stroke | 1400 mm / 1200 mm / 1325 mm |
Spindle specifications to meet a wide variety of machining requirements
The high-rigidity spindle can perform heavy-duty machining of challenging materials and steel, and high-speed machining of non-ferrous materials such as aluminum.
High-speed and high-torque specifications are optionally available.
HCN-4000 NEO / HCN-5000 NEO Tool shank: BT40
Standard 12000 min-1
Spindle output
18.5 kW (25 HP) [40% ED]
15 kW (20 HP) [Cont. rating]
Max. torque: 81.9 N・m [40% ED]
High torque 15000 min-1 (Option)
Spindle output
46 kW (62 HP) [40% ED]
37 kW (50 HP) [Cont. rating]
Max. torque: 200 N・m [40% ED]
High speed 18000 min-1 (Option)
Spindle output
35 kW (47 HP) [40% ED]
26 kW (35 HP) [Cont. rating]
Max. torque: 84 N・m [40% ED]
High speed, high output 20000 min-1 (Option)
Spindle output
42 kW (56 HP) [40% ED]
Max. torque: 161 N・m [40% ED]
High speed 25000 min-1 (Option)
Spindle output
23 kW (31 HP)[40% ED]
Max. torque: 22 N・m [40% ED]
HCN-6800 NEO / HCN-8800 NEO Tool shank: BT50
Standard 10000 min-1
Spindle output
AC 45 kW (60 HP) [40% ED]
Spindle torque: 350 N・m (35.68 kgf・m) [40% ED]
High torque 8000 min-1 (Option)
Spindle output
AC 55 kW (73 HP) [25% ED]
Max. torque: 1413 N・m (144 kgf・m) [10% ED]
High speed 16000 min-1 (Option)
Spindle output
AC 37 kW (50 HP) [40% ED]
Spindle torque: 221 N・m (22.53 kgf・m) [40% ED]
High-rigidity machine construction for stable machining performance
High-rigidity bed
The high-rigidity X-, Z-axis roller guide ensures stability during X- and Z-axis travel.
X-axis slanted design
The mounting surfaces of the X-axis linear guide rails are at different heights to ensure high rigidity and lower total weight. High-speed, high-precision positioning is achieved by driving close to the center of gravity.
The HCN series uses linear roller guides on the X-, Y- and Z-axis for high accuracy and heavy-duty machining.
Rapid traverse rate, maximum feedrate 60 m/min (X, Y, Z axis)
Cone coupling
High positioning accuracy
3 times better than ISO standard
Mazak precision results (ISO)*
*The inspection is conducted according to ISO 230 and ISO 10791 on a recommended foundation with room temperature controlled to 22°C±1°C after the machine has reached operating temperature. Sample results for reference only.
| HCN-4000 NEO HCN-5000 NEO | X-axis | Y-axis | Z-axis |
| Bidirectional positioning accuracy | 9 μm | 9 μm | 9 μm |
| Unidirectional positioning repeatability | 3 μm | 3 μm | 3 μm |
| HCN-6800 NEO | X-axis | Y-axis | Z-axis |
| Bidirectional positioning accuracy | 11 μm | 11 μm | 11 μm |
| Bidirectional positioning repeatability | 6 μm | 6 μm | 6 μm |
| HCN-8800 NEO | X-axis | Y-axis | Z-axis |
| Bidirectional positioning accuracy | 14 μm | 11 μm | 14 μm |
| Bidirectional positioning repeatability | 7 μm | 6 μm | 7 μm |
PALLETECH SYSTEM (Option)
The modular design of the PALLETECH conveniently allows more machines and increased pallet storage capacity to be added to the system after the initial installation in response to changing production requirements. The pallet stocker is available with one, two and three levels for large pallet storage capacity with small floor space requirements.
* The HCN-8800 NEO is compatible with one- and two-level types.
| Minimum | Maximum | ||
| Machine(s) | 1 | 15 | |
| Number of pallets | 1 level | 6 | 240 |
| 2 levels | 12 | 240 | |
| 3 levels | 18 | 240 | |
| Loading station(s) | 1 | 8 | |
| Loading robot | 1 | 1 | |
Software for automatic operation and management of PALLETECH
PMC NEO
- Simulations based on actual machine data allow for quick and easy optimization of system operation plans.
- It assists with the setup of tools and materials required for system operation.
- Remote operation monitoring is available from an office PC, tablet, or smartphone.
Pallet Changer
For higher productivity, set up the next workpiece during machining of the current workpiece.
6-pallet changer (Option)
MPP (MULTI PALLET POOL) (Option)
- * |Compatible with HCN-4000 NEO and HCN-5000 NEO
Maximum of 16 pallets can be stored in the pallet stocker. It will help automating the process with minimal space.
Hydraulic fixtures for higher productivity
Hydraulic power supply A(supply from machine top) (Option)
Hydraulic hoses supply hydraulic power from the top part of the pallet changer to fixtures mounted on each pallet.
Maximum of 12 ports can be arranged. High-power hydraulic supply with 21 MPa is available.
Hydraulic power supply B(supply through pallet) (Option)
A leak-free coupling system supplies hydraulic power to the supply port on the bottom of the pallet. Unlike hydraulic power supply from machine top, this system requires no hydraulic hose or hydraulic rotary coupling. This minimizes interference for easy fixture design and workpiece machining. High-power hydraulic supply with 21 MPa is available.
Loading station: Maximum of 8 ports
Inside machine: Maximum of 4 ports
Robot System (Option)
Interface for connecting an external robot for workpiece loading / unloading to / from automatic hydraulic fixtures is optionally available.
• Field network available
Energy Saver
Energy consumption and the regenerative power produced through the energy saving equipment can be viewed visually on the CNC system to stimulate awareness of energy conservation. In addition, the system can control coolant and other equipment based on the cutting amount to reduce power consumption.
* An optional Smooth coolant system is required for the control of coolant and other equipment.
Environmentally friendly Smooth coolant system (Option)
The coolant tank has a coolant jet that makes a vortex in the center so that small machined chips will not settle in the tank. This feature makes it possible to keep the coolant tank clean and extend the service life of the coolant. Ease of maintenance is also ensured. The frequency of coolant changes is reduced as well as CO₂ emissions at coolant disposal.
Smooth coolant system installation results
- The conventional coolant tank
- Smooth Coolant System
