| Chuck size | From 18" |
| Max. machining diameter | Φ910 mm |
| Max. machining length | 1175 mm / 2165 mm / 3300 mm / 4064 mm |
CNC Turning Centers
SLANT TURN
- Powerful cutting of large-diameter workpieces with high torque spindles
- Machine construction with high rigidity roller guides
- A wide variety of models are available, allowing you to choose the center distance and the spindle bore
SLANT TURN 500, 550, 600 series
Max. machining diameter Φ 910 mm
Max. machining length 1016 mm to 4099 mm
SLANT TURN 800
Max. machining diameter Φ860 mm
Max. machining length 3013 mm to 4033 mm
Spindle bore variations
Φ185 mm
SLANT TURN
500, 500M
Φ275 mm
SLANT TURN
550, 550M
Φ320 mm
SLANT TURN
550, 550M
Option
Φ375 mm
SLANT TURN
600, 600M
SLANT TURN 800
Φ260 mm
SLANT TURN 800
Φ560 mm
SLANT TURN 800
Option
High torque for powerful cutting of large-diameter workpieces
Achieves high-efficiency machining with full power even in low speed ranges
| Max. torque | 7000 N・m |
| Main spindle power | 45 kW (60 HP) |
SLANT TURN 800
Achieves powerful machining of large-diameter workpieces
The powerful spindle motor and the 4 step hydraulic gear shift inside the headstock provide a wide revolution speed range and high cutting torque.
| Max. torque | 12174 N・m |
| Spindle output | 60 kW (80 HP) |
High power milling spindle that rival those of small machining centers
SLANT TURN 500M, 550M, and 600M are capable of highly efficient milling / turning. A high-torque version is also optionally available.
Automatic steady rest with significantly reduced travel time (Optional)
A self-run type steady rest is available as an option. The tailstock can approach much closer to the steady rest for an expanded machining area.
* SLANT TURN 500, 550, and 600 series are only compatible with 2000U / 3000U / 4000U.
Highly rigidity tailstock
The tailstock quill can extend 250 mm making it possible to support both long and short shaft workpieces.
This eliminates the need to remove the steady rest when changing the workpiece from long to short shaft.
SLANT TURN 800
With a high hydraulic pressure thrust of up to 35 kN, it provides strong support for the workpiece.
Max. spindle speed: 1600 min-1 / Max. torque: 7000 N・m
Max. spindle speed: 1000 min-1 / Max. torque: 7000 N・m
Max. spindle speed: 500 min-1 / Max. torque: 7000 N・m
Max. spindle speed: 750 min-1 / Max. torque: 12174 N・m
SLANT TURN 800
| Chuck size | 21", 24" |
| Max. machining diameter | Φ860 mm |
| Max. machining length | 3013 mm / 4033 mm |
