| Pallet size | 800 mm × 800 mm |
| Tool shank (standard) | BT50 |
| Max. spindle speed | 10000 min-1 (rpm) |
| Max. workpiece size | Φ1450 mm × 1600 mm |
5-Axis Machining Centers
VORTEX e-V
- High-accuracy machining with double column structure
- A direct drive motor for table swivel axis (C-axis) is equipped for high-speed cutting feed during 5-axis machining
- Automated systems for diverse workpieces and production volumes
Wide range milling with double column structure
By utilizing double column structure together with long axes strokes, top face milling can be performed with only linear X- and Y-axis positioning, resulting in stable machining accuracy and higher productivity.
Direct drive motor for high-speed cutting feed in 5-axis machining
High-speed, high-precision table (C-axis)
The table uses a direct drive motor for high speed C-axis feed. Since a direct drive motor directly delivers power to C-axis with less power loss, high speed feed is ensured with 5-axis control for enhanced productivity.
PALLETECH HIGH-RISE SYSTEM (2 levels)
- *Compatible only with VORTEX e-1250V/8
- Flexible system expansion is possible in response to changes of production volume
- Flexible linkage with peripheral equipment and systems that increase the rate of automation of long-time automatic operations and machining processes
- Example: PALLETECH MANUFACTURING CELL (1 level)
- Step 1
- Step 2
- Step 3
*The starter set is the required configuration of PALLETECH MANUFACTURING CELL (1 level)
CNC System: MAZATROL SmoothAi
MAZATROL DX
The same environment as the actual MAZATROL SmoothAi machine can be reproduced on an office PC using digital twin technology.
Multiple virtual machines can be built, which can make programming, editing, simulation, and function analysis possible.
The setting data of the actual machine is synchronized, which ensures the accuracy of the digital setup.
- AI Programming
- High speed simulation
- Processing analysis / optimization
Automation
Software development and functions to support automation
