| Chuck size | 6″ |
| Max. machining diameter | Φ23.62" |
| Max. machining length | 23.22" |
| Y-axis travel | 8.27" |
INTEGREX i NEO
- The compact design milling spindle with minimum interference and a variety of the spindle specifications available
- Machining area and Y-axis stroke to expand applicable workpieces size and shape
- Equipped with a high-accuracy built-in motor turning spindle
- A second spindle specification and lower turret specification available for process integration
- Front tool magazine equipped for optimal tool setup for a wide variety of workpieces
Machine construction that achieves high-accuracy and high-productivity
Based on structural analysis, the best machine structure combining turning centers and machining centers was newly designed to achieve stable, high-accuracy machining over the long term. High positioning and machining accuracy are achieved over the entire Y-axis stroke.
- 1: |430 mm
- 2: | Y-axis 300 mm (i-250 NEO, i-350 NEO, i-450 NEO series)
Y-axis 210 mm (i-100 NEO, i-200 NEO series) - 3: | X-axis 695 mm (i-250 NEO, i-350 NEO, i-450 NEO series)
X-axis 535 mm (i-100 NEO, i-200 NEO series)
Milling spindle
Equipped with an ATC compatible milling spindle. The compact design minimizes interference and enlarges the machining area. The 12000 min-1 spindle can perform high efficiency machining of steel and castings. Optional 20000 min-1 spindle is designed for high speed machining of aluminum and small diameter machining. A wide variety of spindle specifications meet production requirements.
| 12000 min-1 [Standard] | 12 kW (16 HP) (40% ED) | i-100 NEO series |
| 18.5 kW (25 HP) (40% ED) | i-200 NEO series | |
| 24 kW (32 HP) (40% ED) | i-250 NEO, i-350 NEO, i-450 NEO series | |
| 12000 min-1 [Option] | 24 kW (32 HP) (40% ED) | i-100 NEO, i-200 NEO series |
| 20000 min-1 [Option] | 24 kW (32 HP) (40% ED) | i-100 NEO, i-200 NEO, i-250 NEO, i-350 NEO, i-450 NEO series |
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. Stabilizes continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors. Furthermore, by accumulating and learning data from subsequent measurements, thermal displacement compensation can be optimized for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Heat displacement control
- Spindle temperature control
It suppressed the thermal displacement of the spindle to prevent lower machining accuracy. - X-, Y-, Z-axis ball screw core cooling (Standard Specification)
Tool magazine at the front of the machine
The tool magazine, ideal for high-mix l low-volume production and situations requiring frequent tool changes, allows for the exchange of multiple tools from the front of the machine. It features a foldable temporary storage table at the lower front of the magazine, providing a place to temporarily set down tools brought in during the exchange process. Additionally, tool attachment and detachment can be performed easily and safely with a button reducing the risk of excessive force and tool drops. Tool shank types can be selected from the standard specification HSK-A63(T63) as well as optional CAPTO C6 and KM4X63.
CNC system
INTEGREX i-100 NEO
INTEGREX i-100S NEO
| Chuck size | 6″ |
| Max. machining length | 33.46" |
INTEGREX i-100ST NEO
| Chuck size | 6″ |
INTEGREX i-200 NEO
| Chuck size | 8″ |
INTEGREX i-200S NEO
| Chuck size | 8″ |
INTEGREX i-200ST NEO
| Chuck size | 8″ |
INTEGREX i-250 NEO
| Chuck size | 8″ |
| Max. machining diameter | Φ26.38" |
| Max. machining length | 39.80" / 59.80" |
| Y-axis travel | 11.81" |
INTEGREX i-250S NEO
| Chuck size | 8″ |
INTEGREX i-250ST NEO
| Chuck size | 8″ |
INTEGREX i-350 NEO
| Chuck size | 10″ |
| Max. machining length | 39.80" / 59.80" / 98.43" |
INTEGREX i-350S NEO
| Chuck size | 10″ |
| Max. machining length | 59.80" / 98.43" |
INTEGREX i-350ST NEO
| Chuck size | 10″ |
| Max. machining diameter | Φ670 mm |
| Max. machining length | 1519 mm |
| Y-axis travel | 300 mm |
INTEGREX i-450 NEO
| Chuck size | 12" |
INTEGREX i-450S NEO
| Chuck size | 12" |
INTEGREX i-450ST NEO
| Chuck size | 12" |
| Max. machining length | 59.80" |
