| Tool shank | CAT No.50 |
| Max. spindle speed | 6000min-1 (rpm) |
| Table size | 82.68" × 29.92" |
Ez Operation
- Enhanced MAZATROL programming with QUICK MAZATROL
- 15-inch touchscreen for intuitive operation
- Easy-to-use screen with customizable display
Ez Machining
- Equipped with heat displacement compensation system "Thermal Shield"
- SMC (SMOOTH MACHINING CONFIGURATION) can adjust machining features according to the processing shape and method.
Ez Setup
Flexible layout
The CNC screen layout is customizable, including the displayed data, menus, and on-screen keyboard. Operators can also adjust the keyboard position for increased ergonomics.
Customizable display
Display any combination of information unique to manufacturing needs. To enhance efficiency, operators can check the data and work simultaneously with minimal screen transitions.
