Smooth MONITOR AX
Machines Status Display
Operator can monitor the operation and the status of various machines regardless of location, including from office computers, large display monitors installed in factory, smartphones and tablets. The system is compatible with MTConnect®, a communication protocol for machine tool, and can connect to and monitor Mazak machines and machines other than those manufactured by Mazak.
- 1: |Machine operation status is displayed according to your plant layout. You can freely select the items to display, therefore you can grasp the information you want to know at a glance.
- 2: |Displays the operating status for the last 24 hours. You can compare the performance of multiple machines and check the operating hours of each machine.
- 3: |Displays the accumulated time of automatic operation. By comparing with the target time, you can see whether production is progressing smoothly.
Data gathering and analyzing
By displaying various information from the machine in easy-to-understand graphs, it can be helpful for improving the production process and increasing productivity.
Some functions can only be used with Mazak products. For more information, please contact your nearest Mazak office.
- Operation Analysis monitor
- Tool Utilization monitor
- Maintenance Manager monitor
- Energy Dashboard monitor
MAZAK SMARTBOX
MAZAK SMARTBOX is a sophisticated security device providing both network and local protection. It supports multiple MTConnect® agents for exporting data from machines to the network via an encrypted port. The SMARTBOX facilitates multi-protocol communication, enabling the connection of multiple machines through a single access port.
-Secures the machine from the network
-Secures the network from the machine
-Enables Edge/Fog computing and analytics
-Uses MTConnect® as a standard supported protocol
-Enables easy monitoring of equipment status and utilization
MAZAK SENSOR BOX
The attached sensors detect the status of the equipment and transfer the collected data to the SMARTBOX. The collected data is converted to MTConnect format and then transferred, so it can be used to collect data from equipment that does not support MTConnect®.
- Data collection from additional sensors
- Data transfer
- Operation monitoring, analysis, and data accumulation
There are three types of MAZAK SENSOR BOX: "SC", "S" and "E".
"SC" type: Collects information from a machine status light and coolant temperature, level
"S" type: Collects information from a machine status light
"E" type: Collects electrical power consumption data
