| Tool shank (standard) | BT30 |
| Table size | 600 mm × 400 mm |
Vertical Machining Centres
FF-400V/30 L
FF-400V/30
- Compact and highly rigid machine equipped with a high-speed BT30 spindle for small parts machining
- Table type is selectable to meet your machining requirements
- Z-axis stroke of 400 mm and maximum tool length of 250 mm allows the machining of large workpieces
- Rapid traverse rate 60 m/min (all axis) and high acceleration (X/Y/Z = 1.1/1.2/1.9G)
Equipped with a high-speed, high-accuracy, compact BT30 spindle for small parts machining
Compact, high performance 12000 min-1 standard spindle. Designed to perform a wide variety of machining efficiently.
20000 min-1 high speed spindle (optional)
High-speed armless tool changer
The standard tool storage capacity is 14 and 26 is available as an option.
High-speed positioning
X-, Y- and Z-axis rapid traverse rate 60 m/min
Table Variations
Fixed table (FF-400V/30 L)
Equipped with a 600 mm × 400 mm fixed table. There is enough machining area even with a tall hydraulic fixture on the top face of the table.
A-axis table (FF-400V/30 L)
The A-axis table allows indexing at any angle. This improves productivity by enabling the machining of top, side and slanted surfaces in a single setup.
A- and C-axis table (FF-400V/30)
Equipped with a highly rigid, 2-axis rotary table (A-axis and C-axis) with support on both ends. Simultaneous 4-axis + A-axis indexing enables multi-surface continuous machining from any angle, achieving process integration.
Ergonomic design for ease of operation
Wide opening and lightweight front door
The front door is designed for easy opening and closing to reduce the load on the operator when loading and unloading workpieces.
Excellent access to table and spindle
Workpiece loading / unloading, fixture changing and checking the spindle tool can all be done in a natural posture. Standard cover coolant prevents the accumulation of chips and the centring conveyor structure discharges chips directly under the table, which reduces the workload of the operator.
The digital setup function can replicate the machine of your factory on the PC at your office. On the machine side, operation programmes can be created while checking the workpiece shape and process, intuitively with touch panel controls.
