| Chuck size | 6″ |
| Max. machining diameter | Φ600 mm |
| Max. machining length | 590 mm |
| Y-axis travel | 210 mm |
INTEGREX i NEO
- Compact design milling spindle with minimum interference and a variety of spindle specifications available
- Machining area and Y-axis stroke to expand applicable workpieces size and shape
- Equipped with a high-accuracy built-in motor turning spindle
- A second spindle and lower turret specification is available for process integration
- Front tool magazine equipped for optimal tool setup for a wide variety of workpieces
Machine construction that achieves high-accuracy and high-productivity
Based on structural analysis, the best machine structure combines turning and machining centres to achieve stable, high-accuracy machining over the long term. High positioning and machining accuracy are achieved over the entire Y-axis stroke.
- 1:430 mm
- 2: | Y-axis 300mm (i-250 NEO, i-350 NEO, i-450 NEO series)
Y-axis 210mm (i-100 NEO, i-200 NEO series) - 3: | X-axis 695mm (i-250 NEO, i-350 NEO, i-450 NEO series)
X-axis 535mm (i-100 NEO, i-200 NEO series)
Milling spindle
Equipped with an ATC compatible milling spindle. The compact design minimises interference and enlarges the machining area. The 12000 min-1 spindle can perform high-efficiency machining of steel and castings. Optional 20000 min-1spindle is designed for high-speed machining of aluminium and small diameter machining. A wide variety of spindle specifications meet production requirements.
| 12000 min-1 [Standard] | 12 kW (16 HP) (40% ED) | i-100 NEO series |
| 18.5 kW (25 HP) (40% ED) | i-200 NEO series | |
| 24 kW (32 HP) (40% ED) | i-250 NEO, i-350 NEO, i-450 NEO series | |
| 12000 min-1 [Option] | 24 kW (32 HP) (40% ED) | i-100 NEO, i-200 NEO series |
| 20000 min-1 [Option] | 24 kW (32 HP) (40% ED) | i-100 NEO, i-200 NEO, i-250 NEO, i-350 NEO, i-450 NEO series |
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. Stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF and other factors. Furthermore, by accumulating and learning about the data from subsequent measurements, thermal displacement compensation can be optimised for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Heat displacement control
- Spindle temperature control
It suppresses the thermal displacement of the spindle to prevent lower machining accuracy. - X-, Y-, Z-axis ball screw core cooling (standard specification)
Tool magazine at the front of the machine
The tool magazine, ideal for high-mix, low-volume production and situations requiring frequent tool changes, allows for the exchange of multiple tools from the front of the machine. It features a foldable temporary storage table at the lower front of the magazine, providing a place to set down tools brought in during the exchange process. Additionally, tool attachment and detachment can be performed easily and safely with a button, reducing the risk of excessive force and tool drops. Tool shank types can be selected from the standard specification HSK-A63(T63) as well as optional CAPTO C6 and KM4X63.
CNC system
Innovative MAZATROL CNC system for higher-productivity
MAZATROL SmoothAi provides unsurpassed productivity through an even faster and higher precision control, while elevating your production with AI and digital twin technology and advanced automation capabilities.
INTEGREX i-100 NEO
INTEGREX i-100S NEO
| Chuck size | 6″ |
| Max. machining length | 850 mm |
INTEGREX i-100ST NEO
| Chuck size | 6″ |
INTEGREX i-200 NEO
| Chuck size | 8″ |
INTEGREX i-200S NEO
| Chuck size | 8″ |
INTEGREX i-200ST NEO
| Chuck size | 8″ |
INTEGREX i-250 NEO
| Chuck size | 8″ |
| Max. machining diameter | Φ670 mm |
| Max. machining length | 1011 mm / 1519 mm |
| Y-axis travel | 300 mm |
INTEGREX i-250S NEO
| Chuck size | 8″ |
INTEGREX i-250ST NEO
| Chuck size | 8″ |
| Max. machining length | 1519 mm |
INTEGREX i-350 NEO
| Chuck size | 10″ |
| Max. machining length | 1011 mm / 1519 mm / 2500 mm |
INTEGREX i-350S NEO
| Chuck size | 10″ |
| Max. machining length | 1519 mm / 2500 mm |
INTEGREX i-350ST NEO
| Chuck size | 10″ |
INTEGREX i-450 NEO
| Chuck size | 12" |
INTEGREX i-450S NEO
| Chuck size | 12" |
INTEGREX i-450ST NEO
| Chuck size | 12" |
