| Chuck size | 8″ |
| Max. machining diameter | Φ480 mm |
| Max. machining length | 500 mm / 1016 mm |
INTEGREX j NEO
- Reduce machining cycles and increase productivity with a compact, high-power milling spindle
- Maximize cutting performance with a high-power, high-torque motor spindle
- Visualize energy consumption with the Energy Saver function
- Simplify automation with teaching-less robot cells, the Ez LOADER series
Providing many benefits compared to a turret lathe
Challenges of a turret lathe
The INTEGREX j NEO series achieves high productivity
Turning spindle and milling spindle suitable for various production types
| Specifications | Milling spindle (40% ED) | Main spindle (40% ED) | ||
| INTEGREX j-200 NEO | Compact single spindle turret | 0.0001° index | 12000 min-1, 18.5 kW, 57.3 N·m | 5000 min-1, 18.5 kW, 326 N·m |
| INTEGREX j-300 NEO | 12000 min-1, 22 kW, 75.4 N·m | 4000 min-1, 22 kW, 387 N·m | ||
| INTEGREX j-400 NEO | 3300 min-1, 30 kW, 883 N·m | |||
The milling spindle unit can be indexed in 0.0001° increments, allowing outer diameter, end face, and diagonal machining with a single tool. Similarly, the second spindle performs various machining with a single tool, reducing cycle times.
- 1: |210°
- 2: |30°
High-torque, high-output main spindle with enhanced performance
The powerful, high-torque built-in motor spindle delivers excellent surface finishes. With high-output and high-torque, it provides superior machining performance, contributing to increased productivity.
Second spindle performs continuous machining
The second spindle enables back-side machining of the workpiece, allowing continuous machining through the first and second processes. This helps shorten lead times and improve machining accuracy. It also eliminates the need for re-centring and phase alignment during workpiece transfer, effectively reducing setup time. The second spindle is equipped with the same highly reliable built-in motor spindle as the main spindle.
Tool magazine located at the front of the machine
Shorten tool setup time
The front-mounted tool magazine has a standard capacity of 36 tools, with optional 72-tool capacities. It simplifies tool changes and setup, helping reduce setup time. It also provides a large capacity tooling not easily achieved with turret lathes, supporting flexible high-mix production. Long tools can also be used for deep-hole machining and other demanding applications.
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. Stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF and other factors. Furthermore, by accumulating and learning about the data from subsequent measurements, thermal displacement compensation can be optimised for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Energy Saver
Environmentally friendly Smooth coolant system (Option)
Reduced frequency of tank cleaning
The coolant tank has a coolant jet that makes a vortex in the centre so that small machined chips will not settle in the tank. This feature makes it possible to keep the coolant tank clean and extends the service life of the coolant. Ease of maintenance is also ensured. The frequency of coolant changes is reduced as well as CO₂ emissions at coolant disposal.
- The conventional coolant tank
- Smooth Coolant System
INTEGREX j-200 NEO
INTEGREX j-200S NEO
| Chuck size | 8″ |
| Max. machining length | 910 mm |
INTEGREX j-300 NEO
| Chuck size | 10″ |
| Max. machining diameter | Φ510 mm |
| Max. machining length | 629 mm / 1165 mm |
INTEGREX j-300S NEO
| Chuck size | 10″ |
| Max. machining length | 1165 mm |
INTEGREX j-400 NEO
| Chuck size | 12" |
INTEGREX j-400S NEO
| Chuck size | 12" |
