Contact Us
More
Vertical Machining Centres
VC-Ez IP
High-performance vertical machining centres
  • Powerful, high-torque spindle for higher productivity
  • Largest table and machining area in its class
  • Designed for stable, high-accuracy machining
  • MAZATROL SmoothEz: CNC system for unsurpassed usability and high-productivity
Spindle output: 18.5 kW / 7.5 kW (5 min. rating / Cont. rating)
BT40, 12000 min-1 Spindle
A powerful, versatile spindle engineered for a wide range of machining applications, from heavy duty steel removal to high-precision aluminium machining. Featuring ceramic long-life bearings, the spindle reduces thermal instability and provides high-precision machining.
Reliable high-speed ATC and tool magazine
The 30-tool magazine capacity minimises tool setup requirements and provides flexibility for a wide range of workpiece applications.
Tool change time
(chip-to-chip)
Max. tool length
(From gauge line)
Max. tool diameter
(With adjacent tool)
Max. tool diameter
(No adjacent tool)
Max. tool weight
3.8 sec.350 mmΦ80 mmΦ150 mm8 kg
The table of the VC-Ez IP series has the largest machining area in its class and can load large fixtures and workpieces.
 Table sizeMax. workpiece size.
VC-Ez 410 IP950 mm × 410 mm950 mm × 410 mm × 450 mm
VC-Ez 510 IP1250 mm × 492 mm1250 mm × 492 mm × 570 mm
VC-Ez 660 IP1400 mm × 610 mm1400 mm × 610 mm × 570 mm
Linear roller guides
A high-speed linear roller guide is utilised on all axes, providing high positional accuracy and long-term durability.
Coolant / Cabinet cooler / Chip disposal
Flood coolant
Coolant through spindle system
Equipped with "QUICK MAZATROL", an improved version of MAZATROL programming. Programs can be made intuitively with the 15" touch screen while checking the workpiece shape and work process. If combined with the SmoothCAM Ai software (separately sold), machines in your factory can be replicated on your office PC, allowing digital setup of your machine to improve operational efficiency.
VC-Ez IP
VC-Ez 410 IP
Tool shankBT40
Max. spindle speed12000 min-1
Table size950 mm × 410 mm
VC-Ez 510 IP
Tool shankBT40
Table size1250 mm × 492 mm
VC-Ez 660 IP
Tool shankBT40
Table size1400 mm × 610 mm
