Minokamo Plant 1
Minokamo Plant 1 is the largest production facility in our company, where the INTEGREX multi-tasking machine series, CNC turning centres, compact vertical machining centres and laser processing machines are produced.
Fully networked with Minokamo Plant 2, this is a facility that specialises in machining with high-efficiency automation, where production is optimised to meet a wide range of customers' production requirements.
This facility has advanced production equipment, such as FMS lines with 5-face machining centres for large workpieces, equipment used to produce ball screw components and a clean assembly area which is required for laser processing machines.
| Post code | 505-0005 |
| Address | 333 Yamazaki, Naka-Hachiya, Hachiya-cho, Minokamo City, Gifu-Pref. |
| TEL | +(81)0574-25-8311 |
| FAX | +(81)0574-28-2145 |
Access
By Car
- About 30 minutes from the World Headquarters
- From Chubu Centrair International Airport
Centrair Higashi interchange... Chita Peninsula Road... Isewangan Expressway... Tokai-Kanjo Expressway... Minokamo interchange
About 1 hour 40 minutes - About 10 minutes from the Minokamo interchange
By Train
- About 8 minutes by car from JR Mino-Ota Station
- About 30 minutes by car from Meitetsu Inuyama Station
