Additive Manufacturing (AM) Technology
Additive manufacturing (AM) is a manufacturing technology that creates shapes by layering materials. Unlike conventional machining processes or pouring materials into a mould, AM allows for the creation of shapes by layering only the necessary amount of material in the required places. By utilising these methods, the degree of freedom in product design is expanded, opening new possibilities in manufacturing.
[Advantages of additive manufacturing technology]
  • Complex shapes can be moulded in one piece, significantly reducing assembly time
  • Minimise finishing allowance and create a close version to the finished product
  • Flexibly accommodates prototyping and design changes without moulds
  • Maximise material usage efficiency by layering only the necessary amount
  • Design flexibility that surpasses conventional methods, such as weight reduction and functional integration
Growing demand for additive manufacturing technology
In recent years, interest in additive manufacturing has been growing worldwide. Several factors underpin this trend, significantly transforming the nature of manufacturing. One key factor is the ability to drastically shorten development processes. Since design data can be reflected directly to physical objects, prototyping and revision cycles can be accelerated. Furthermore, its ability to produce only what is needed and where it is needed, reduces inventory management burdens, enables local production and provides an opportunity to rethink traditional supply chains. Additionally, environmental benefits such as minimising material waste and enabling efficient energy use cannot be overlooked. The combination of these values, positions additive manufacturing as a crucial technology supporting the manufacturing industry of the new era.
Accelerating development and optimising inventory and materials
  • ●|Reduction of lead times
  • ●|Reduction of inventory management
  • ●|Reduction of material waste
Laser metal deposition
Laser metal deposition technology is a manufacturing method that instantly melts and solidifies metal powder using a laser. It enables high-precision and dense forming, making it suitable for complex shapes, thin walls and fine structures. Furthermore, it can form corrosion-resistant, wear-resistant and heat-resistant layers with sub-millimetre thickness on the base material surface, achieving higher adhesion compared to plating or thermal spraying. It is an advanced technology that can be used to fill only the necessary parts and is effective for repairs and modifications.
1: Deposited zone 2: Dilution zone 3: Laser 4: Metal powder 5: Melt pool
Wire arc AM
Wire-arc AM technology is a fabrication method that melts and deposits metal wire through arc discharge. Compared to powder, it is easier to handle and enables stable supply at a low cost. Its high fabrication speed makes it ideal for producing large parts and performing build-up repairs. Hybrid multi-tasking machines enable machining during the layering process, allowing the shape of each layer to be refined as the build progresses. This process removes impurities and irregularities from the layered surface, significantly improving manufacturing precision. Ultimately, this results in more faithful shape reproduction and high-quality internal properties. Compared to laser metal deposition, it offers superior productivity and cost-effectiveness, making it widely used for manufacturing large components in aircraft and industrial machinery.
1: Metal wire 2: Deposited zone 3: Dilution zone 4: Assist gas 5: Arc 6: Melt pool
The diverse applications of additive manufacturing technology
AM is a flexible technology that can be used not only to manufacture new parts, but also to repair existing parts and add surface functions. It can be used for a variety of applications, including manufacturing, repair and coating, greatly increasing productivity and added value at manufacturing sites.
3D additive manufacturing
Direct additive manufacturing allows for optimised structures, such as hollow shapes and topologies which are difficult to achieve with conventional machining or casting processes. This enables new design concepts through weight reduction and functional integration.
Marine propeller
Roll die cutter (Blade)
Repairing abrasion or damaged parts
By layering only the required amount of material on abrasion or damaged areas, it is possible to restore the original shape. Parts can be reused, reducing costs and making effective use of resources.
Forging mould
Crushing blade
A coating that increases hardness and wear abrasion
By layering high-hardness alloys or wear-abrasion materials on the surface of the base material, the lifespan of parts can be significantly extended. This is effective for parts used in harsh environments, such as tools and moulds. By controlling the laser beam diameter, it is possible to adjust the coating thickness and processing speed.
Coupling
Industrial rolls
Layered deposition of dissimilar metals
By layering different metal materials, multiple properties such as wear resistance and corrosion resistance can be imparted, dramatically increasing design freedom and allowing the creation of composite material parts that were not possible with conventional methods.
Plant valves
Hydraulic pressure piston sliding part
Examples of process integration using additive manufacturing technology
AM coating as an alternative to plating
Traditionally, plating was applied for surface hardening and wear resistance, followed by grinding for finishing. With AM, layering wear-resistant materials directly onto the surface enables plating replacement. Combined with finishing mirror grinding, it efficiently achieves highly durable and precise surface treatment.
Significantly reduce process lead time and CO2 emissions
The conventional process took 12 days, but with the introduction of the AM machine, it was shortened to 1 day.
Lead time
91% reduction
CO2 emissions from conventional processes, approximately 50 kg, reduced to approximately 30 kg with the introduction of AM machines.
CO2 emissions
40% reduction
Repairing parts by wire arc AM
It solves challenges in manual repair (build-up welding, finishing) such as lengthy operations, quality inconsistencies and frequent setup changes between machining processes. It achieves repair automation as a solution to labour shortages and technology inheritance.
WorkpieceCrushing blade of the crusher
IndustryGeneral machinery
MaterialWear-abrasion steel
Workpiece sizeΦ500 mm × 80 mm
Hardness (equivalent to HRC60)
A: HRC
B: Distance from the end face of the test specimen (mm)
Flow of introducing AM machines
Mazak provides total support from technology selection to post-delivery
Consideration and Proposal
  • ●|Confirm workpiece geometry and application to assess suitability for AM
  • ●|Select the optimal AM process
  • ●|Propose optimal specifications including modelling size, accuracy and peripheral equipment
  • ●|Estimate and present cost, lead time and quality improvement effects
Demonstration and Quotation
  • ●|Verify forming performance using actual workpieces and test specimens
    • ・|Condition Setting: Optimise forming parameters
    • ・|Test Specimen Creation and Strength Testing: Evaluate mechanical properties
    • ・|Simulated Machining: Confirmation based on anticipated actual operation
  • ●|Quotation
    • ・|Provide a quotation including machinery, peripheral equipment and start-up
Factory inspection, Delivery and Training
  • ●|Machine delivery, setup and modelling confirmation conducted with on-site supervision
  • ●|Establish local production conditions and install machines
  • ●|Training to acquire operational and maintenance skills
Operation
  • ●|Ongoing support for operational data analysis and condition optimisation
  • ●|Online support for operational assistance and troubleshooting
  • ●|On-site visits by technicians when issues occur
Related information
