| Tool shank (standard) | BT50, CAT No.50 |
| Max. spindle speed | 10000 min-1 |
| Table size | 1740 mm × 750 mm |
Vertical Machining Centres
FJV 5 Face
- Units and functions that make 5-surface machining accessible as standard equipment, achieving process integration
- Highly rigidity double column construction for high-accuracy machining
- High-accuracy built-in motor spindle for high-efficiency machining
- Designed for high-efficiency in machining large workpieces, with a wide lineup that can handle long shaft workpieces
Units and functions that make 5-Face machining accessible as standard equipment
Four side face machining with one angle tool
The MAZAK 5 Face angle head is capable of powerful cutting with its unique hydraulic pressure clamping unit that provides a strong fixation.
Wide angle head cutting range
Compact angle head reduces interference with the workpiece for large machining area.
Enhanced versatility
The dedicated angle tool magazine has a storage capacity of 8 tools, which makes it possible to handle a wide variety of workpieces.
Simplified programming
The MAZATROL conversational program for 5-surface machining makes it easy to create programs for side face machining.
- 1: The double column construction delivers high-accuracy machining over extended periods of operation
- 2: High-accuracy positioning by ball screw and direct servo mounting
- 3: Spindle temperature control prevents changes in machining accuracy
- 4: Linear roller guides for high-rigidity are used on all axes
Ball screw core cooling
Based on spindle speed and temperature of the machine, the Ai Thermal Shield suppresses changes in the cutting edge position. It stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF and other factors.
Equipped with a built-in spindle, it eliminates the need for driving gear. It can reduce power loss and minimise vibration during high-speed operation to ensure exceptional surface finishes and maximum tool life.
High-torque spindle and high-speed spindle (BT40) are available as options
A 10000 min-1 standard spindle that can handle machining of various materials such as cast iron, steel, and nonferrous metal. A 7000 min-1 high-torque spindle (optional) that is effective for rough machining of steel and cast iron. A BT40 18000 min-1 high-speed spindle (optional) that enables highly efficient machining of nonferrous metal and difficult machining material through high-speed machining are available.
| Standard spindle | High-torque spindle* | High-speed spindle(BT40)* | ||
(Cont. rating) | 30 kW (40 HP) | 22 kW (30 HP) | 26 kW (35 HP) | |
(Cont. rating) | 239 N・m | 318 N・m | 57 N・m | |
Tool shank | BT50, | BT50, | BT40, |
- *Option
The symmetrical spindle unit design minimises spindle displacement due to heat generation during machine operation.
Reduces program creation time
3D ASSIST
Create programs directly from 3D CAD data
QUICK EIA
Visualisation of G code(EIA) programs
By visualising the G code(EIA) program, it supports checking and editing of small program increments. Visible search on touch screen can reduce the time for program checking.
