| Tool shank (standard) | BT40 |
| Table size | 800 mm × 460 mm |
Vertical Machining Centres
FJV (BT40)
- Double column construction designed for high-accuracy machining over extended periods of operation
- BT40 high-rigidity spindle for the latest cutting technologies, from heavy cutting to high-speed machining
- CNC system can be selected from MAZATROL SmoothG and MAZATROL SmoothC
- 1: The double column construction delivers high accuracy machining over extended periods of operation
- 2: High-accuracy positioning by ball screw and direct servo mounting
- 3: Spindle temperature control prevents changes in machining accuracy
- 4: Linear roller guides for high-rigidity are used on all axes
Ball screw core cooling
Temperature controlled cooling oil circulates through the ball screw cores. It ensures stable machining accuracy over extended periods of high-speed operation.
Symmetrical headstock design
The symmetrical headstock design together with the integral spindle / motor minimises spindle displacement due to heat generated by the spindle operation.
Based on spindle speed and temperature of the machine, the Ai Thermal Shield suppresses changes in the cutting edge position. It stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors.
*Available with the MAZATROL SmoothG.
High-accuracy built-in motor spindle for high-efficiency machining
From nonferrous metals to high-hardness materials, the machine provides high-efficiency machining for a variety of applications in the semiconductor, electronics, aircraft, and mould industries.
Spindle variation from high-torque to high-speed machining
- 12000 min-1 standard spindle for a wide range of applications from nonferrous metal to steel cutting
- 12000 min-1 high-torque spindle (option) for heavy-duty, rough machining of steel and cast iron
- 18000 min-1 high-speed spindle (option) for machining of aluminium, copper, and other similar materials
- 25000 min-1 high-speed spindle (option) for high-speed die machining with small diameter end mills.
Unsurpassed ease of operation with touch screen. A wide range of applications supports from setup to machining.
MAZATROL SmoothC
Simplified display and key input operation
