| Tool shank (standard) | BT50, CAT No.50 |
| Max. spindle speed | 10000 min-1 |
| Table size | 1740 mm × 750 mm |
Vertical Machining Centres
FJV (BT50)
- Highly rigidity double column construction for high-accuracy machining
- High-accuracy built-in motor spindle / motors for high-efficiency machining
- Designed for high-efficiency in machining large workpieces, with a wide lineup that can handle long shaft workpieces
- 1: The double column construction delivers high-accuracy machining over extended periods of operation
- 2: High-accuracy positioning by ball screw and direct servo mounting
- 3: Spindle temperature control prevents changes in machining accuracy
- 4: Linear roller guides for high-rigidity are used on all axes
Ball screw core cooling
Temperature controlled cooling oil circulates through the ball screw cores. It ensures stable machining accuracy over extended periods of high-speed operation.
Based on spindle speed and temperature of the machine, the Ai Thermal Shield suppresses changes in the cutting edge position. It stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors.
High-accuracy integral spindle / motors for high-efficiency machining
Equipped with a integral spindle / motor, it eliminates the need for driving gear. It can reduce power loss and minimise vibration during high-speed operation to ensure exceptional surface finishes and maximum tool life.
High-torque spindle and high-speed spindle (BT40) are available as options
A 10000 min-1 standard spindle that can handle machining of various materials such as cast iron, steel, and nonferrous metal. A 7000 min-1 high-torque spindle (optional) that is effective for rough machining of steel and cast iron. A BT40 18000 min-1 high-speed spindle (optional) that enables highly efficient machining of nonferrous metal and difficult machining material through high-speed machining are available.
| Standard spindle | High-torque spindle* | High-speed spindle(BT40)* | ||
Cont. rating | 30 kW (40 HP) | 22 kW (30 HP) | 26 kW (35 HP) | |
Cont. rating | 239 N・m | 318 N・m | 57 N・m | |
Tool shank | BT50, | BT50, | BT40, |
- *Option
The symmetrical spindle unit design minimises spindle displacement due to heat generation during machine operation.
More options to integrate processes and achieve high-productivity
Multi-surface machining attachment (optional) enables four face machining with one angle tool
An additional axis (optional) that enables control of the 4th axis by commands in the machining programme
2-pallet changer (optional) to load the next workpiece during the machining of the current workpiece
Reduce program creation time
Programs can be created while checking the machining shape and process, which helps prevent mistakes and shorten creation time. By touching the 3D model, you are instantly moved to the corresponding processing unit, making it easy to modify the programme.
3D ASSIST
Create programs directly from 3D CAD data
QUICK EIA
Visualisation of G code (EIA) programs
By visualising the G code (EIA) program, it supports checking and editing of small program increments. Visible search on touch screen can reduce the time for program checking.
