| Spindle bore | Φ76 mm |
| Chuck size | 8″ |
| Max. machining diameter | Φ320 mm |
| Max. machining length | 860 mm |
CNC Turning Centres
HQR NEO
- 3 turret / 2 spindle machine construction for faster cycle times
- Bar work capacity up to Φ102 mm (option)
- Automation system for various applications from chuck to shaft workpieces
- The CNC system MAZATROL SmoothG3 for highly efficient machining with 3 turret
Machine construction for significantly reduced cycle time
In workpieces where there is a difference in machining amounts between the first and second operations, our machine achieves significant productivity improvement even compared to 2 turret / 2 spindle CNC turning centre.
Bar work capacity
| Machine model | Main spindle | Second spindle |
| HQR-200/3 NEO | Φ65 mm | Φ65 mm |
| Φ102 mm* | Φ65 mm | |
| HQR-250/3 NEO | Φ80 mm | Φ65 mm |
| Φ80 mm* |
* Optional
A variety of automation systems such as bar feeders, workpiece unloaders and robots are optionally available to support long-term automatic operation.
- Step 1
- Step 2
- Screen design that takes advantage of touch operation speeds up task such as programming and editing.
- Complex movements of the three turrets are supported by various interference check functions to ensure safe operation.
The display divided into three columns makes it easy to confirm the operation of each turret. The EIA/ISO programming screen displays the waiting command positions side by side, enabling intuitive and easy programme editing.
Various programme check functions
Program checks are also difficult on 3-turret machines because of the complexity of turret movements, which makes it difficult to maintain synchronisation of the individual turrets.
These functions support programme checking without disrupting the synchronisation of the turrets.
Virtual Machining
Safety Shield
This inter-grid single block operation ensures the synchronisation between turrets, preventing interference and increasing downtime caused by programme misalignment.
A: Turret A
B: Turret B
▲: Operation stop
A: Turret A
B: Turret B
▲: Operation stop
Override synchronised operation
Override, which allows adjustment of programme processing time, is reflected not only in the operating time of the turrets but also in the standby time, thus enabling programme operation without disrupting synchronisation between turrets. This allows for high-accuracy interference checks.
With Override synchronised operation (50%)
A: Turret A
B: Turret B
1: Dwell (standby time)
2: Supporting Functions
3: No programme misalignment
Without Override synchronised operation (50%)
A: Turret A
B: Turret B
Manual pulse handle operation
The machining programme can be operated at any speed by turning the handwheel of the CNC system by hand. The approach position and points where interference is likely to occur can be carefully checked.
HQR-200/3 NEO
HQR-250/3 NEO
| Spindle bore | Φ91 mm |
| Chuck size | 10″ |
