| Tool shank | BT50, CAT No.50 |
| Max. workpiece size | Φ1250 mm × 1250 mm |
| Max. spindle speed | 500 min-1 |
INTEGREX e-RAMTEC
- Long X-axis and Y-axis strokes for high-accuracy machining of large parts
- Ram spindle for deep inner diameter boring and milling
- High-efficiency machining is achieved with the MAZATROL SmoothAi CNC
High-accuracy machining with double column structure
Double column structure suitable for top face machining of large parts
By taking advantage of the double column structure and the long X-axis stroke beyond the milling spindle, top face milling can be performed with only linear X- and Y-axis positioning, resulting in stable machining accuracy and higher productivity.
X-axis stroke
Ram spindle mounted on 5-axis controlled vertical multi-tasking machines
Ram spindle
Mounted alongside the milling spindle, the ram spindle provides 900 mm of vertical travel, enabling turning and milling of deep internal features on large workpieces. This expanded machining capability allows greater process integration.
Automatic ram spindle tool changer
A dedicated tool magazine is mounted to hold 40 turning and milling tools. The automatic ram spindle tool changer enables a wide variety of machining and automatic changes to spare tools during long-term machining.
Milling spindle
Built-in motor milling spindle is both compact and high power. In addition to the 10,000 min-1 standard spindle for various materials, there is a 5,000 min-1 spindle* suitable for high-torque machining of difficult-to-machine materials.
*Option
The B-axis, which is the swivel axis of the milling spindle with a travel range of 150° (-30° to 120°), utilises a roller gear cam to eliminate backlash, ensuring high-accuracy positioning over long periods.
Turning spindle
The high-power, high-torque turning spindle performs efficient rough machining and finishing of large-diameter, heavy-duty workpieces. In addition, the C-axis can position in 0.0001° increments and ensures high-accuracy machining.
Higher productivity in multi-product machining
2-pallet changer for efficient setup
2-pallet changer promptly replace pallets loaded with heavy workpieces. Setup station rotates with high precision. In addition, the workpiece centring tool* supports the operator to smoothly perform the alignment work required for turning.
*Option
TOOL HIVE (Option)
The TOOL HIVE is a rack-type magazine that combines storage for over 180 tools with space-saving design. Loading/unloading and data editing of tools are available by the dedicated operation panel TOOL HIVE TERMINAL, reducing setup time. Storage can be expanded after the first installation.
MAZATROL SmoothAi
MAZATROL SmoothAi offers high-operability, high-speed and high-accuracy to improve productivity. Coupled with Smooth CAM Ai, advanced digital simulation is realised through Digital Twin technology.
