| Tool shank | CAT No.50 |
| Max. workpiece size | Φ1450 mm × 1600 mm |
| Max. spindle speed | 500 min-1 |
INTEGREX e-V
- Double-column machining centre performs multi-surface machining, free-form surface machining by 5-axis control and turning for higher productivity
- Highly rigid structure for stable high-accuracy machining
- Table enhanced with direct drive motor for high-torque and high-speed positioning
- Automation systems to meet your production requirements
Wide range milling with double column construction
Double column construction suitable for top face machining of large workpieces
High-power milling spindle and direct-drive table for turning
Enhanced milling performance for high-productivity
Three milling spindles are capable of machining a wide range of materials from steel to non-ferrous materials. All of them achieve compact size and high-power by adopting a built-in motor.
High-torque, high-speed table
(turning & C-axis)
A direct drive motor that can output large torque in a compact volume is used to achieve both the high torque required for turning large workpieces and the high response that enables agile positioning.
Compatible models: INTEGREX e-1250V/8, e-1250V/8S, e-1600V/10, e-1600V/10S
High-torque table (turning & C-axis)
The turning spindle, driven by a high power motor and two-gear ranges, performs highly efficient machining of large diameter and heavy workpieces from rough machining to finishing. The C-axis can be indexed in 0.0001° indexing increments for high-accuracy machining.
Compatible models: INTEGREX e-1850V/12, e-1850V/25S
Automated systems for diverse workpieces and production volumes
PALLETECH HIGH RISE SYSTEM (2-levels) *Compatible with INTEGREX e-1250V/8 only
PALLETECH MANUFACTURING CELL (1-level)
Flexible system expansion
- The system is scalable according to the production demands
- Flexible linkage with peripheral equipment which enhances long-term automatic operation and automation of machining processes
| First installation* | Example of system expansion 1 | Example of system expansion 2 | |
| Number of machines | 1 | 2 | 3 |
| Loading stations | 1 | 2 | 2 |
| Pallet stockers | 6 | 14 | 20 |
- *Starter set for the PALLETECH MANUFACTURING CELL (1-level)
MAZATROL SmoothAi CNC system
MAZATROL SmoothAi provides unsurpassed productivity through an even faster and higher precision control, while elevating your production with AI and digital twin technology and advanced automation capabilities.
MAZATROL programmes are automatically generated from 3D CAD data. AI learns machining know-how from previously generated programmes, automatically calculates the machining process, and generate the optimal program.
