| Chuck size | 8″ |
| Max. machining diameter | Φ500 mm |
| Max. machining length | 500 mm / 1016 mm |
INTEGREX j-200 NEO
Entry-level multi-tasking machine
- Exceptional milling versatility allows cutting from all directions with a single tool, reducing the number of tools required
- Wide range of machining options with B-axis indexed every 0.0001°
- The main spindle utilises a high-power, high-torque built-in motor spindle
- Visualise energy consumption and regenerative power with the “Energy Saver” feature on the CNC system
- Easy automation with Ez LOADER, an automation cell with a collaborative robot
Providing many benefits compared to a turret lathe
Challenges of a turret lathe
High-performance specifications for high-productivity
| Specifications | Milling spindle (40% ED) | Main spindle (40% ED) | ||
| INTEGREX j-200 NEO | Compact single spindle turret | 0.0001° index | 12000 min-1, 18.5 kW, 57.3 N·m | 5000 min-1, 18.5 kW, 326 N·m |
The milling spindle unit can be indexed in 0.0001° increments, allowing outer diameter, end face, and diagonal machining with a single tool. Similarly, the second spindle performs various machining with a single tool, reducing cycle times.
- 1: |180°
- 2: |30°
Main spindle: designed for a wide range of workpieces
The high-power, high-torque built-in motor spindle at 18.5 kW and 326 Nm provides excellent machining capabilities.
Second spindle performs continuous machining (INTEGREX j-200S NEO)
This is effective in reducing setup time for workpieces that require phase alignment. Continuous first and second machining to the finished workpiece contributes to machining accuracy.
Energy Saver
Energy consumption and the regenerative power produced through the energy saving equipment can be viewed visually on the CNC system to stimulate awareness of energy conservation.
INTEGREX j-200 NEO
INTEGREX j-200S NEO
| Chuck size | 8″ |
| Max. machining length | 910 mm |
