| Pallet size | Φ600 mm × 500 mm |
| Tool shank (standard) | BT40, CAT No.40 |
| Max. workpiece size | Φ730 mm × 450 mm |
5-Axis Machining Centres
VARIAXIS C
- Large B-axis tilt angle and long X- and Z-axis stroke for multi-surface and 5-axis machining
- High-accuracy machining with a highly rigid table supported on both ends and advanced compensation technology
- Automation systems for mass production and multi-variety processing, with a wide range of options
Long stroke for multi-surface and 5-axis machining
A wide stroke range of the X- and Z-axis allows the tool to approach the tip and lower part of the workpiece in multi-surface and 5-axis machining, where the B-axis is tilted significantly. It ensures vibration-free machining with short tool projection.
The high feed rates significantly reduce non-cutting time in simultaneous 5-axis machining, achieving higher productivity.
Spindle options for machining workpieces
Variety of spindle specifications for various materials
We offer a lineup of high-rigidity and high-speed spindles that can perform heavy-duty machining of steel as well as high-speed machining of non-ferrous materials such as aluminium.. You can select the optimal spindle to suit your workpiece.
| Standard | High-torque* | High-speed* | ||
| Spindle speed | 12000 min-1 | 15000 min-1 | 18000 min-1 | 20000 min-1 |
| Output (40% ED) | 11 kW (15 HP) | 46 kW (62 HP) | 30 kW (40 HP) | 42 kW (56 HP) |
| Torque (40% ED) | 70 N・m | 200 N・m | 105 N・m | 161 N・m |
| Tool shank | BT-40 / CAT No.40 / BIG-PLUS No.40* / HSK-A63* | |||
- *Option
Machining example (test results)
15000 min -1 high-torque spindle
Φ80 mm face mill (6 teeth)
Speed: 995 min -1
Feedrate: 1552 mm/min
Depth of cut: 5.8 mm
Material: S45C
Material removal rate: 581 cm³/min
High-rigidity table
The tilting rotary table is supported at two ends. High-speed, high-precision, and high-rigidity machining is achieved by utilising roller gear cams in the B-axis and C-axis to eliminate backlash.
| Model | VARIAXIS C-600 | VARIAXIS C-700 |
| Max. workpiece diameter | Φ730 mm | Φ850 mm |
| Max. workpiece height | 450 mm | 500 mm |
| Max. workpiece weight | 500 kg | 700 kg |
| C-chamfer | C110 mm | C90 mm |
VARIAXIS C-600 1: H450 mm 2: Φ730 mm 3: C110 mm
VARIAXIS C-700 1: H500 mm 2: Φ850 mm 3: C90 mm
High-rigidity structure and MAZATROL SmoothAi for high-accuracy machining
Position misalignment and incline of the rotary axes can automatically be measured and compensated to realise high accuracy 5-axis machining.
The centre and tilt of rotary axes can be automatically measured and compensated as well as linear axes.
- * Wireless touch probe RMP600 is an optional equipment.
Based on spindle speed and temperature of the machine, the Ai Thermal Shield suppresses changes in the cutting edge position. It stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF and other factors. New algorithms have improved the accuracy of compensation. Furthermore, by accumulating and learning data from subsequent measurements, thermal displacement compensation can be optimised for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Smooth Ai spindle*
*Option
2-pallet changer*
The optional 2-pallet changer allows you to load materials for the next processing step or setup during machining, improving productivity.
| VARIAXIS C-600 | VARIAXIS C-700 | |
| Pallet size | 500 mm × 500 mm | 500 mm × 500 mm |
| Max. workpiece size | Φ730 mm × 450 mm | Φ730 mm × 500 mm |
| Max. loading weight | 500 kg | 600 kg |
*Option
Expandable multi-pallet changer system*
By setting up materials to multiple pallets, the machine can run unmanned for longer periods of time, thus increasing machine availability.
The pallet size, maximum workpiece size and load are the same as those of the 2-pallet changer specification.
*Option
- 2PC
- 4PC, 6PC
MULTI PALLET POOL (MPP)
The MPP (MULTI PALLET POOL) is a space-saving multi-stage pallet stocker system developed in response to the growing demand for automation. This automation system is ideal for small-batch, multi-product production and will dramatically improve productivity. The MPP is designed to be attached to the side of the machine, allowing access to the workpiece from two locations: the operator's door and the loading station.
Flexible pallet stocker capacity
6, 12 and 18 pallet storage capacities are available after initial installation.
- 1. 6PC: 3 pallets × 2 levels
- 2. 12PC: 6 pallets × 2 levels
- 3. 18PC: 6 pallets × 3 levels
MAZATROL SmoothAi drives innovation for even higher productivity
SMC PLUS
The cutting point of the EIA programme are compared with the 3D model, and the command points are automatically corrected to reduce cutting residue and generate a smooth path trajectory, resulting in high-quality machining.
Machining features including cycle time, finished surface, and machining shape can be adjusted according to material requirements and machining methods. Since the operator can easily adjust and change settings, it is especially effective for complex workpiece contours defined in small programme increments.
Digital Twin software for high-productivity*
Digital twins recreate real-world factory environments in cyberspace, bringing about innovation in production. By utilising digital twin software that is compatible with MAZATROL SmoothAi and leverages IoT technology, the machines in the factory can be virtually replicated, leading to significant efficiency improvements in the production process. It provides your office PC with the same environment as the actual MAZATROL SmoothAi. Virtual machine construction enables programming, editing, simulation, and analysis for multiple machines. The setting data of the actual machine is synchronised, which ensures the accuracy of the digital setup.
*Option
