| Clamp interface | HSK-A100 holder |
| Tool shank (standard) | BT40, CAT No.40 |
| Max. workpiece size | Φ350 mm × 315 mm |
5-Axis Machining Centres
VARIAXIS i-300 AWC
- Compact workpiece stocker and tool magazine enable continuous machining
- Standard Smooth AWC software for Auto Work Changer management and operation
- High-speed and high-precision machining of complex components
A compact automation system for the efficient machining of a wide variety of small batch parts
Automatic Work Changer (AWC)
- 1: Loading station
- 2: Work stocker
- 3: Table
- 4: Loader vertical movement
- 5: Loader horizontal movement
- 6: Loader rotation
Selectable work stocker
After the initial installation, the work stocker can be expanded from 32 to 40 work stockers, depending on the production requirement.
Max. workpiece size
1: Diameter: Φ350 mm
2: Height: 315 mm
The maximum weight is 65 kg including the work holder.
Smooth AWC
Smooth AWC is the software for setup, management and automatic operation of the VARIAXIS i-300 AWC, incorporated in the CNC system, MAZATROL SmoothAi.
- 19” touch panel for intuitive operation
- The system monitoring screen displays the status of the entire AWC system
- Setup instructions are displayed during automatic operation
Operators are able to switch between the CNC screens on this machine to operate it.
- 1: Schedule
- 2: Missing and unnecessary tools list
- 3: Production schedule
- 4: Setup work instructions
- 5: Alarm display
Compact tool magazine with large tool storage capacity
Multiple drum tool magazine
The multiple drum tool magazine automatically supplies up to 505 tools to the tool magazine on the machine. With this system, the operator can safely setup/remove tools and input tool data even during machining.
Compact Footprint
The AWC is designed to provide a more space-efficient tool magazine. By stacking drum magazines that can hold 30 tools, the system minimises space expansion even when the number of tools is increased.
Compared to the rack-type, large-capacity tool magazine "Tool Hive," the floor space has been reduced by 35.6%.
Large-capacity, space-saving tool storage for the machining of a wide variety of small-batch parts
The number of magazines can be selected according to the number of tools required.
- image 1
- image 2
- image 3
- image 4
- image 5
- image 6
- image 6
Wide range of spindle specifications
A wide range of spindles are available, from high-torque spindles suitable for heavy-duty cutting of difficult-to-cut materials, steel and castings, to high-speed machining spindles for aluminium, which are required for high-precision parts and aerospace components.
Built-in motor structure
The built-in motor structure reduces power loss and minimises vibration at high speed machining. This ensures an exceptional surface and maximum tool life.
Spindle temperature control
Temperature-controlled cooling oil is circulated around the spindle bearings and headstock. It suppressed the thermal displacement of the spindle to prevent lower machining accuracy.
| Spindle speed : | Standard | High-torque* | High-speed* | |
| 12000 min-1 | 18000 min-1 | 25000 min-1 | 30000 min-1 | |
| Output (40% ED) | 22 kW (30 HP) | 35 kW (47 HP) | 23 kW (31 HP) | 23 kW (31 HP) |
| Max. torque (40% ED) | 71.6 N・m | 134 N・m | 22 N・m | 22 N・m |
| Tool shank | BT-40 / CAT No.40 / BIG PLUS-40* / HSK-A63* | BT-40 / CAT No.40 / BIG PLUS-40 / HSK-A63 | HSK-A63 | HSK-F63 |
- *Option
Smooth Ai Spindle*
If chatter vibration occurs during milling, the vibration sensor and AI adaptive control automatically change the machining conditions to suppress the chatter vibration. With AI, a less-skilled operator can make adjustments easily in a short time.
*Option
1: Chatter occurs
2: Chatter eliminated
Highly-rigid structure for stable high-accuracy machining
High-rigidity table
This table adopts a structure supported by both ends with two points on the A-axis, enabling high-rigidity and high-precision machining. The table can be indexed in 0.0001° increments in both the A- and C-axis, allowing complex multi-face and 5-axis machining.
Ball screw core cooling
Linear roller guides
By using roller guides with excellent high-speed and durability for the X-, Y-, and Z-axis, the machine has achieved high processing rigidity to maintain precision and minimised the need for maintenance.
Compact spindle cartridge
The compact spindle and the work holder are clamped on the HSK-A100 interface. With minimum interference between the spindle and table, there is no need for any shimming when machining areas close to the table. The tool projection can be shortened, allowing for stable machining of workpieces with complex shapes.
Environmentally friendly
Energy Dashboard*
This application supports energy conservation by visualising and analysing power consumption.
*Option
Energy consumption is displayed on the process home screen.
- Total energy consumption (of workpiece in operation)
- Current energy consumption
1: Graphic display linked to energy consumption
2: Energy consumption by workpiece
3: Converts energy consumption into CO2 emissions/electricity charges
Clean coolant System *
The large-capacity 1100 L cutting water tank has a coating that prevents chips from sticking to it, and is designed to constantly create a vortex inside the tank using a water jet. By adopting this system, chips are guided to the filtration device together with the coolant, and more than 98% of particles larger than 10 μm are removed by a special cyclone filter.
In addition, the clean coolant system itself is maintenance-free, significantly reducing the time required to clean filters and tanks.
- *Included in optional coolant package.
