| Chuck size | 6″ |
| Max. machining diameter | Φ600 mm |
| Max. machining length | 590 mm |
| Y-axis travel | 210 mm |
INTEGREX i NEO
- Compact design milling spindle with minimum interference and a variety of spindle specifications available
- Machining area and Y-axis stroke to expand applicable workpieces size and shape
- Equipped with a high-accuracy built-in motor turning spindle
- A second spindle and lower turret specification is available for process integration
- The front tool magazine delivers optimal tool setup for a wide range of workpieces, while the optional rear tool magazine is suited for integration with automated systems.
Machine construction that achieves high-accuracy and high-productivity
The integrated machine structure combines turning and machining centre technologies to deliver stable, high-accuracy machining over the long term. High positioning and machining accuracy are achieved over the entire Y-axis stroke.
- 1:430 mm
- 2: |Y-axis 210 mm (i-100 NEO, i-200 NEO series)
Y-axis 300 mm (i-250 NEO, i-350 NEO, i-450 NEO series) - 3: |X-axis 535 mm (i-100 NEO, i-200 NEO series)
X-axis 695 mm (i-250 NEO, i-350 NEO, i-450 NEO series)
Milling spindle
Equipped with an ATC-compatible milling spindle featuring a wide motion range. The 12000 min-1 spindle can perform high-efficiency machining of steel and castings. Optional 20000 min-1spindle is designed for high-speed machining of aluminium and small diameter machining. A wide variety of spindle specifications meet production requirements.
| 12000 min-1 [Standard] | 12 kW (16 HP) (40% ED) | i-100 NEO series |
| 18.5 kW (25 HP) (40% ED) | i-200 NEO series | |
| 24 kW (32 HP) (40% ED) | i-250 NEO, i-350 NEO, i-450 NEO series | |
| 12000 min-1 [Option] | 24 kW (32 HP) (40% ED) | i-100 NEO, i-200 NEO series |
| 20000 min-1 [Option] | 24 kW (32 HP) (40% ED) | i-100 NEO, i-200 NEO, i-250 NEO, i-350 NEO, i-450 NEO series |
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. Stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF and other factors. Furthermore, by accumulating and learning about the data from subsequent measurements, thermal displacement compensation can be optimised for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Heat displacement control
- Spindle temperature control
It suppresses the thermal displacement of the spindle to prevent lower machining accuracy. - X-, Y-, Z-axis ball screw core cooling (standard specification)
Tool magazine
Front tool magazine
The front-mounted tool magazine enables tool changes from the front of the machine, minimizing operator movement and helping to reduce setup time. It is well suited for applications that require frequent tool changes, such as high-mix, low-volume production. It features a foldable temporary storage table at the lower front of the magazine, providing a place to set down tools brought in during the exchange process. Additionally, tool attachment and detachment can be performed easily and safely with a button, reducing the risk of excessive force and tool drops. Tool shank types can be selected from the standard specification HSK-A63(T63) as well as optional CAPTO C6 and KM4X63.
Rear tool magazine (Option)
The tool magazine is located at the rear of the machine, providing a clear workspace at the front and increasing the available working area. This configuration is well suited for integration with automated systems.
CNC system
Innovative MAZATROL CNC system for higher-productivity
The MAZATROL SmoothAi CNC combines high-speed, high-precision control with AI-powered intelligence, digital twin technology and advanced automation capabilities, to maximise productivity and efficiency.
INTEGREX i-100 NEO
INTEGREX i-100S NEO
| Chuck size | 6″ |
| Max. machining length | 850 mm |
INTEGREX i-100ST NEO
| Chuck size | 6″ |
INTEGREX i-200 NEO
| Chuck size | 8″ |
INTEGREX i-200S NEO
| Chuck size | 8″ |
INTEGREX i-200ST NEO
| Chuck size | 8″ |
INTEGREX i-250 NEO
| Chuck size | 8″ |
| Max. machining diameter | Φ670 mm |
| Max. machining length | 1011 mm / 1519 mm |
| Y-axis travel | 300 mm |
INTEGREX i-250S NEO
| Chuck size | 8″ |
INTEGREX i-250ST NEO
| Chuck size | 8″ |
| Max. machining length | 1519 mm |
INTEGREX i-350 NEO
| Chuck size | 10″ |
| Max. machining length | 1011 mm / 1519 mm / 2500 mm |
INTEGREX i-350S NEO
| Chuck size | 10″ |
| Max. machining length | 1519 mm / 2500 mm |
INTEGREX i-350ST NEO
| Chuck size | 10″ |
INTEGREX i-450 NEO
| Chuck size | 12" |
INTEGREX i-450S NEO
| Chuck size | 12" |
INTEGREX i-450ST NEO
| Chuck size | 12" |
