| Chuck size | 6" |
| Max. machining diameter | Φ340 |
| Max. machining length | 553 mm |
CNC Turning Centres
QT-COMPACT
Compact, high-performance CNC turning centres
- High cost-effectiveness and rigidity
- Extensive lineup for various applications such as turning, milling, Y-axis machining and second spindle options
- Equipped with MAZATROL SmoothC CNC system, with outstanding operability and high-speed, high-precision control
Integral spindle / motor to achieve high productiveness and high precision
All series are equipped with integral spindle / motors, which allows various operations such as heavy-duty machining of ferrous metals, or high-speed machining of non-ferrous metals such as aluminium. Gears and belts, which are causes of vibrations, are not used to ensure high-accuracy.
The main spindle can also operate C-axis indexing in 0.0001°minimum increments and contouring.
100 Series: 6”
200 Series: 8”
300 Series: 10”
12 position drum turret with milling function
The drum turret is designed for minimum interference. By using non-lift rotary indexing, high-speed turret clamping / unclamping can be performed without interference. Tool holders are rigidly mounted on the turret by four bolts. A 24 position turret is also optionally available.
Second Spindle
By orienting both spindles, high-accuracy workpiece transfer from the main spindle to the second spindle can be performed for continuous machining. 100 Series: 5”, 200 / 300 Series: 6”
Y-axis for machining complex shapes
The long Y-axis stroke ensures for high-accuracy and high-efficiency machining of complex workpieces.
Y-axis stroke: 100(±50 )mm
Extensive lineup with milling functions in all series
Machine can be selected according to your production style
| Spindle | Rotary tool spindle | Y-axis | Second spindle | Tailstock | Universal | ||
| 100MY L | 15 kW | 5.5 kW | ● | ー | ● | 500U | |
| 100MS L | ー | ● | ー | ー | |||
| 100MSY L | ● | ● | ー | ||||
| 200MY L | 15 kW | 5.5 kW | ● | ー | ● | 500U | 1000U |
| 200MS L | ー | ● | ー | ー | |||
| 200MSY L | ● | ● | ー | ー | |||
| 300MY L | 15 kW | 5.5 kW | ● | ー | ● | 500U | 1000U |
| 300MS L | ー | ● | ー | ー | |||
| 300MSY L | ● | ● | ー | ー | |||
High-productivity even in limited spaces
Machines with the same universal require the same floor space
For machines with the universal of 500U, all machines from the 100 series to the 300 series can be installed with the same floor space: 4.39m2.
For machines with the universal of 1000U, series 200M, 200MY, 300M, 300MY can be installed with the same floor space: 5.96m2.
- 1: | 4.39 m2(2600 mm ×1690 mm)
- 2: | 5.96 m2(3385 mm × 1760 mm)
Unsurpassed operability with high-speed / high-accuracy controls
Programs can be easily made by simple key controls. With MAZATROL programming, even unexperienced operators can swiftly create programs. There is a home screen for each process. Progress and availability for production, programming, tool data management, setup, and maintenance can be managed centrally.
Various options for advanced automation
Automatic front door
It supports 3-step open/close speeds and has a built-in safety device to stop operation by a touch pressure sensor. Automatic opening/closing with area sensors are also available.
Tool eye
Tool setup is done by simply bringing the tool tip into contact with the tool eye, which will automatically register the tool to the CNC system, so tool setup time is considerably reduced.
Automatic parts catcher
This function will automatically carry out finished workpieces into a parts box outside the machine. It can be combined with bar feeders or workpiece discharging conveyors to achieve an automated system.
Automatic workpiece measurement
This function uses a turret-mounted touch sensor to automatically measure the inside and outside diameters, surface irregularity etc. of the machined workpiece to perform tool corrections and to maintain machining accuracy during unattended operation.
Automation for mass production
The QT-COMPACT L series can add safety fences, interlocks, safety functions for operators
for high level automations using robot systems.
