INTEGREX j NEO
Entry model for multi-tasking machines
  • Reduce tool changes with single-tool multi-directional milling spindle
  • Reduce machining cycles and increase productivity with a compact, high-power milling spindle
  • Maximize cutting performance with a high-power, high-torque motor spindle
  • Visualize energy consumption with the Energy Saver function
  • Simplify automation with teaching-less robot cells, the Ez LOADER series
Weak points of turret lathe
Insufficient number of tools
Difficult to check interference with large workpieces
Mill tool holders are expensive
The INTEGREX j NEO series achieves high productivity
Turning spindle and milling spindle suitable for various production types
SpecificationsMilling spindle (40% ED)Main spindle (40% ED)
INTEGREX j-200 NEOSingle spindle turret1° index12000 min-1,
7.5 kW, 27.5 N・m
5000 min-1,
15 kW, 167 N・m
INTEGREX j-200 NEO High-performanceCompact single spindle turret0.0001° index12000 min-1,
18.5 kW, 57.3 N・m
5000 min-1,
18.5 kW, 326 N・m
INTEGREX j-300 NEOCompact single spindle turret1° index
Option: 0.0001° index
12000 min-1,
22 kW, 75.4 N・m
4000 min-1,
22 kW, 387 N・m
INTEGREX j-400 NEO3300 min-1,
30 kW, 883 N・m
The milling spindle unit can be indexed in 1 degree increments, allowing outer diameter, end face, and diagonal machining with a single tool. Similarly, the second spindle performs various machining with a single tool, reducing cycle times. The 0.0001° indexing available in the High-performance specification of the j-200 NEO, and as an option for the j-300 NEO and j-400 NEO series, offers enhanced versatility for a variety of workpieces.
  • 1: |210°
  • 2: |30°
1° indexing
High-torque, high-output main spindle with enhanced performance
The powerful, high-torque built-in motor spindle delivers excellent surface finishes. Its high output and high torque provide superior machining performance, contributing to increased productivity.
Second spindle performs continuous machining (INTEGREX j-200S NEO, j-200S NEO High-performance, j-300S NEO, j-400S NEO)
The second spindle enables back-side machining of the workpiece, allowing continuous machining through the first and second processes. This helps shorten lead times and improve machining accuracy. It also eliminates the need for re-centering and phase alignment during workpiece transfer, effectively reducing setup time. The second spindle is equipped with the same highly reliable built-in motor spindle as the main spindle.
Tool magazine located at the front of the machine
Shorten tool setup time
The front-mounted tool magazine has a standard capacity of 20 tools, with optional 36- or 72-tool capacities. It simplifies tool changes and setup, helping reduce setup time. It also provides large capacity tooling not easily achieved with turret lathes, supporting flexible high-mix production. Long tools can also be used for deep-hole machining and other demanding applications.
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. Stabilizes continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors. Furthermore, by accumulating and learning about the data from subsequent measurements, thermal displacement compensation can be optimized for each machining environment to stabilize machining accuracy.
Energy Saver
temp
Environmentally friendly Smooth coolant system (Option)
Coolant discharge amount 1: Face milling 2: End milling 3: Drilling
The coolant tank has a coolant jet that makes a vortex in the center so that small machined chips will not settle in the tank. This feature makes it possible to keep the coolant tank clean and extend the service life of the coolant. Ease of maintenance is also ensured. The frequency of coolant changes is reduced as well as CO₂ emissions at coolant disposal.
Chuck size: 8-inch
INTEGREX j-200 NEO
Chuck size8″
Max. machining diameterΦ500 mm
Max. machining length500 mm / 1016 mm
INTEGREX j-200 NEO (High Performance Specification)
Chuck size8″
Max. machining diameterΦ480 mm
  • Second Spindle
INTEGREX j-200S NEO
Chuck size8″
Max. machining length910 mm
  • Second Spindle
INTEGREX j-200S NEO (High Performance Specification)
Chuck size8″
Chuck size: 10-inch
INTEGREX j-300 NEO
Chuck size10″
Max. machining diameterΦ510 mm
Max. machining length629 mm / 1165 mm
  • Second Spindle
INTEGREX j-300S NEO
Chuck size10″
Max. machining length1165 mm
Chuck size: 12-inch
INTEGREX j-400 NEO
Chuck size12"
  • Second Spindle
INTEGREX j-400S NEO
Chuck size12"
