| Max. machining diameter | Φ500 mm |
| Max. machining height | 462 mm |
| Chuck size | 12" to 18" |
CNC Turning Centers
MEGA TURN
- Large machining area
- Outstanding cutting capacity for high productivity
- Automatic tool changer for further improvement of productivity
- Symmetrical machines can be lined up to build an efficient line
Unique design for large machining area
The Max. machining diameter is not limited by the machine construction.
The travelling column design has been adopted instead of cross rail design that interferes with the workpiece and turret.
This leads to eliminating limitations of the machining diameter caused by the machine structure, allowing for a large machining area.
| Machining Capacity | ||
| Model | 1: Diameter | 2: Height |
| 500, 500S, 500M, 500MS | Φ500 mm × H462 mm | |
| 600, 600S | Φ630 mm × H550 mm | |
| 600M, 600MS | Φ600 mm × H550 mm | |
| 900, 900S, 900M, 900MS | Φ920 mm × H800 mm | |
| 1600, 1600M | Φ1650 mm × H900 mm | |
Equipped with a highly rigid, high-torque turning spindle
High rigidity headstock for machining heavy workpieces
MEGA TURN 900 Series
Max. material removal rate: 960 cm³/min
Material: S45C / Spindle speed: 80 min-1 /
Feedrate: 0.8 mm/rev. / DOC: 8 mm
Max. workpiece weight: 3000 kg
Output: 30 kW (40 HP) [40% ED] Max. torque: 3655 N・m
Process integration by high-speed turret lathe and milling performance
Turret for mounting up to 12 tools
The turret is rigidly clamped by a high-index coupling for high-performance machining including intermittent cutting. Additionally, it is designed for the minimum workpiece interference with boring bars while turning.
Milling performance for process integration
For large diameter cylindrical components used in construction machinery, heavy electrical equipment, aircraft, and related fields, turning and milling process can be integrated on a single machine. This significantly reduces production lead times.
Automatic Tool Changer for increased productivity (option)
Automatic tool changer that eliminates the worries about the number of tools
To eliminate the reduction in the number of tools due to interference between the boring tool and the workpiece, we have developed an unique automatic tool changer. It can recall tools from adjacent tool magazines when necessary, so not only can the interference be eliminated, but it also allows for full tool mounting, which greatly reduces setup man-hours.
(No automatic tool changer)
(Automatic tool changer equipped)
Variety of selection to suit your production system
2 pallet changer for reduced setup time and long continuous machining, available with mirror-image versions for efficient operation.
2-pallet changer (900 series) (option)
Productivity is increased by the ability to setup the next workpiece during the machining of the current one.
Continuous machining capability of 1st and 2nd pallets ensures long-hour machining.
Mirror-image versions available to solve placement problems (except for 1600, 1600M)
Two machines can be operated by a single operator.
By combining mirror-image versions with standard version machines, the machine layout can be set up with a shorter traveling distance between machines, when only one operator is available for production (compared to installing two standard version machines).
Floor space can also be reduced.
Selectable CNC systems
MEGA TURN 500 /
MEGA TURN 500S
MEGA TURN 500M /
MEGA TURN 500MS
MEGA TURN 600 /
MEGA TURN 600S
| Max. machining diameter | Φ630 mm |
| Max. machining height | 550 mm |
| Chuck size | 18" to 24" |
MEGA TURN 600M /
MEGA TURN 600MS
| Max. machining diameter | Φ600 mm |
MEGA TURN 900 /
MEGA TURN 900S
| Max. machining diameter | Φ920 mm |
| Max. machining height | 800 mm |
| Chuck size | 21" to 36" |
MEGA TURN 900M /
MEGA TURN 900MS
MEGA TURN 1600
| Max. Machining Diameter | Φ1650 mm |
| Max. machining height | 900 mm |
| Chuck size | Φ1250 mm to Φ1500 mm |
MEGA TURN 1600M
