| Max. worksheet width | 1525 mm |
| Max. worksheet length | 3050 mm |
| Laser power | 3.0 kW / 6.0 kW |
Laser Processing Machines
OPTIPLEX Ez
- Equipped with Mazak SmoothCUT oscillator, which enables high-speed cutting through beam optimization
- Machine design focused on accessibility and ease of operation
- Equipped with the MAZATROL SmoothLx CNC for enhanced usability
- Comprehensive oscillator warranty support is available
Wide opening doors
Sliding doors are installed on the front and side face of the machine, minimizing the floor space required. Both doors have wide openings, providing large space. The sliding door on the side of the OPTIPLEX 4220 Ez can be opened from both left and right, making it easier for an operator to load and unload workpieces.
2: OPTIPLEX 3015 Ez: 3210 mm, OPTIPLEX 4220 Ez: 3130 mm
Easy accessibility
The short distance from the operator to the table allows for easy access to a workpiece from the side of the machine.
| OPTIPLEX 3015 Ez | 380 mm |
| OPTIPLEX 4220 Ez | 390 mm |
Operability of CNC control
CNC control for 2D laser processing machine
Operator can easily zoom in and out on the display screen with fingertips.
The wide screen also allows the operator to check nesting at a glance.
Machine monitor
The machine monitor supports operators by providing easy access to the torch and machine information. Machine processing status information is displayed with the machine image, allowing operators to grasp the machine processing status and detailed data at a glance.
- 1: | Alarm displayed at door open
- 2: | Select and display the required information from machine status, cutting conditions, position & laser, and measurement.
- 3: | Torch information display
One-touch operation
Mazak’s fiber laser oscillator that achieves high quality and high productivity
Mazak SmoothCUT
- High cost performance is achieved by controlling and optimizing a high quality beam based on the type of material and material thickness.
- Stable processing of highly reflective materials such as copper and brass
- Mazak iCONNECTTM machine remote diagnosis (M2M service) enables remote diagnosis of the oscillator
- Available with a long-term warranty of up to 10 years. 5-year standard warranty and up to 5 years of additional warranty are available.
Comprehensive warranty support
By subscribing to the Mazak iCONNECT™ M2M service, we will check the condition of oscillator through remote diagnosis and also conduct an interview with customers to identify the cause of the malfunction. Based on that, we will determine the appropriate repair method for the oscillator and carry out either repair or replacement depending on the extent of the issue. The warranty covers not only the oscillator but also the fiber cable.
Warranty period
The Mazak SmoothCUT comes with a standard 5-year warranty. For added peace of mind, optional seven‑year and ten‑year warranties are also available.
OPTIPLEX 3015 Ez
OPTIPLEX 4220 Ez
| Max. worksheet width | 2050 mm |
| Max. worksheet length | 4120 mm |
